Old 05-24-2013, 06:12 PM
Rowdy Rebel's Avatar
Rowdy Rebel Rowdy Rebel is offline
Default 106 won't start....sort of.
I'm sure the answer is here on the forum somewhere....
I stopped mowing the other day and gassed up the 106...and it wouldn't start. Battery is good and the tractor will start and run if I jump from the + terminal to the A on the starter/generator. I guess my question is how to figure out which switch is the bad switch (Ignition key switch, Magnetic or Neutral safety switch).
Any help is appreciated!!
Thanks
Old 05-24-2013, 06:28 PM
Muzzy Muzzy is offline
It could be the solenoid too.
Old 05-24-2013, 07:39 PM
Hope this helps. It is the sequential order of the Start Circuit and wire color correct...
Old 05-25-2013, 09:32 AM
Thanks for the input....I'll give an update soon.
Old 06-20-2013, 10:03 AM
The 106 is up and running...new blades and belts also. The issue was with some old cracked wires so I'm thinking a new wiring harness this winter.
Old 06-20-2013, 10:37 AM
Glad to hear your 106 is running!
Old 06-20-2013, 11:15 AM
PaulS's Avatar
PaulS PaulS is offline
Sounds like your 106 is a bit of a Rowdy Rebel also. Glad you got it going again.
Old 06-20-2013, 11:22 AM
Good to hear!
Old 07-04-2013, 12:55 AM
Sorry I haven't le[t up here....took on a window replacement project on the old house (20+) and having the Cub back to form was expected !! This thing would be "trail rated" by Jeep I'm sure as I have not been stuck in the wood yet. They just don't make them like this anymore !!
