Latest project after I got P.O.d at CUB letting the pump adapters go NLA for the Cyclops tractors with the Sundstrand pumps was to see if I could come up with a replacement that was also stronger than the OEM part. I called Cub to see if they had any plans on making more of these and the attitude was we could care less you have an obsolete tractor “ have you looked for them on the web” give me a break. Gotta love it I’m not gonna part out a perfectly good tractor over a crappy part like this. Glad I took drafting in school. These engage the whole shaft, the flange is also threaded so you don’t need 3 hands to get everything lined up. Only problem is they will be in the $100 ea. range. I want to get one of them installed and test it before I offer them for sale. I think the test unit will be my 1572 so I can also try out a drive shaft conversion at the same time. The diesel's are hard on drivelines so it seems like the way to go.
Is this for only if equipped with the rear pto?
2182 super 60"haban deck IH 782 50"deck |
![]() Quote:
![]() Quote:
Hmmmmmmmmm,,,,,,
![]() That splined joint is susceptible to rust. The Mitsubishi MT 372 had a similar spline on the mower drive, it is also a diesel. ![]() When I had the MT 372, I used to disassemble and grease it EVERY year, my splined joint survived well. The MT 372 part is also a NLA. A lot of MT 372s' are DOA because of the unavailability of that part. It might be worthwhile considering a grease fitting on the adapter, for that reason. ![]() |
CAD
The adapter is not supposed to move on the shaft. This goes on the pump input. For what it's worth I'm gonna put a little JB weld on the splines when I put it on and Loc-Tite the bolt.
![]() Quote:
The mower deck, and I believe the entire mower drive was Haban, similar construction to the Cub Cadet 1872 deck. So I believe there was little design interaction between Mitsubishi and Haban. |
i like where your going with this. id love to get rid of that whimpy drive shaft.
127 - 48'' deck + tiller. 1512- 46" GT deck & bagger 1872- 60" Haban 1772 turbo diesel- Iron rear + KW loader + backhoe + 3 point. Case 580CK Ford 850 International TD-8E |
whats the difference between the 72 and 82 series drive shaft? i know length is, how much are they off by? anything else?
Ken
The 72 is the rag joint type, the 82 is the CV type. Problem with the 82 style is they have splines on the ends to fit into the CV joint and they are a PITA to shorten and get them straight. I'm going to try using a 2000 series shaft. I can cut it, put a section of 5/8" shaft inside and then drill it and pin it for what ever length I need. I've done this on the JD dumper I built last year and so far it's working.
