Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Briggs & Stratton Engines
Old 05-15-2013, 12:11 PM
C57 Blue C57 Blue is offline
Question Need help
I have a 2160 cub cadet lawn tractor. When I turn off the key they tractor keeps on running. But is sounds like it is running on one cylinder. Can anybody help me with this problem that I'm having. Thanks
Old 05-15-2013, 12:53 PM
First, welcome to OCC...
Second, the 2160 rolled out of the Factory with a 16HP B & S engine it. Is that way you have..???
Old 05-16-2013, 01:10 PM
The one I have is 16HP v-twin OHV. Cub cadet 134-266-100, 2160 If this can be any help to you,
Old 05-16-2013, 01:14 PM
My mowe is 16HP, V-Twin with OHV. The Model number is 134-266-100 2160,the number on the motor is 803447 if this can be any help to you. I hope you can help me with my problem that I am having with this mower.
Old 05-16-2013, 02:02 PM
There is NO such model number I can find (803447). Would this more be likely.....303447?
Old 05-16-2013, 02:41 PM
The mags have a kill wire that grounds them out with the key in the off position. They also have a diode in each wire to keep them from grounding each other out. Check and see if the diode is open or the kill wire came off the mag.
Old 05-16-2013, 07:55 PM
I had a Vanguard that a mouse ate through one of the kill wires to one mag and it did the same thing. Get ready to pull the engine out. Not a big deal to do it. A couple hours and a few cold ones. I suggest that you pull the fender pan and undo the drive shaft at the pump and have someone hold the shaft tight to the engine as you move the engine forward because the coupling is a MAJOR PITA to get back together once it comes apart, ask me how I know.
Old 05-17-2013, 06:17 AM
Default You could be right
Yes you could be right because the plate had some dirt on it. Can you help me with my problem? Thank you.
Old 05-17-2013, 06:35 AM
I'll look into it today.
Old 05-17-2013, 08:56 AM
Here is your Ignition Circuit. As Sam stated, you might look at the "Yellow" wire(s) to see if they are intact.
