Old 05-12-2013, 10:23 PM
hdsdcouple's Avatar
Default stuck clutch need help
Well i bought this little tractor today, she has been sitting for a while, exposed to the weather. When i push the clutch in all the way it is still ingaged. Any helpful tips?
Old 05-12-2013, 11:02 PM
With the pedal pushed, drive a screwdriver between the clutch and pressure plate, both sides!!
Old 05-12-2013, 11:10 PM
hdsdcouple's Avatar
so they are just sort of stuck from sitting around all winter? Is that common on these tractors and is there something i can do to keep it from happening again?
Old 05-12-2013, 11:16 PM
cubby102's Avatar
cubby102 cubby102 is offline
other then just keep using it theres really not a whole lot to do.. it happense from time to time, store it indoors or keep it covered when not in use helps alot too
Old 05-12-2013, 11:31 PM
If it is gonna set for more than a WEEK, use the brake lock to keep the clutch pressure off the plates!!
Old 05-13-2013, 08:37 PM
cubfixer's Avatar
cubfixer cubfixer is offline
I have had a stuck disk. Just pushed in on the clutch and locked it down. Took a hammer and tagged (gently) the outside of the fiber disk. separated right away. To keep it from happening again, keep the clutch dry. It can rust together overnight (don't ask me how I know!).
John
Old 05-13-2013, 09:31 PM
hdsdcouple's Avatar
well thanks for the help every one, i got her unstuck this evening. looks like it was just some surface rust keeping the friction. I got the feeling i be chasing some bugs around for a bit. Hope you all don't get mad at me for asking all the questions that are going to come up. I would rather ask and look stupid then break stuff.
Old 05-13-2013, 10:31 PM
cubby102's Avatar
Never to many questions
