Old 05-05-2013, 11:57 PM
Conductor562's Avatar
Conductor562 Conductor562 is offline
Default Clutch Cushioning Spring - 62 Original
As I've stated in other posts, my 62 O was a freebie that I rescued from the scrap yard. The PO stated he quit using it because a spring broke on the clutch. After looking a few times I couldn't find anything missing. Yesterday I spent a considerable amount of time removing 50 years of grease, after which I compared my clutch to the diagram in the operators manual. The only spring that looks amiss is the clutch cushioning spring. About 2 rings of it are still there, but I'm assuming it was once bigger than that. Forgive my novice ignorance, but what is the functionality of this spring? Could it alone be enough to disable the clutch? Sorry for the stupid questions, just trying to learn.
Old 05-07-2013, 08:17 AM
Is this and the "teaser spring" the same thing?
Old 05-07-2013, 08:57 AM
ihcc104's Avatar
ihcc104 ihcc104 is offline
Is there any way you can get us a picture?
- Cory Sanderson
Old 05-07-2013, 09:27 AM
MBounds's Avatar
MBounds MBounds is offline
Yes, that is the teaser spring. It's purpose is to ease the clutch plate onto the engine drive plate without requiring a chiropractor to remove the whiplash you'll get without it. It should have about 4 coils. Replace it and you probably will be good to go... Note the grease zerk on the bearing (see lube chart in Operators Manual)..... Most don't even know its there. No grease and the clutch won't move back and forth... The Original is the only one to have this feature.
Myron B
CCSupplyRoom
Myron B
East Texas
Most of of the fleet:
Cub Cadets: 2 Orig,70,71,122,123,104,124,126,86,128, 109,800,1200,1250,1450,1650,IH 682,782D,IH 982. Cadets: 76,SO76,80,81,IH 182. RER: 60,75. Elec 95. Trailers: #2, #3, #4, 1200-A,1200-B,1200-C, 2000. IH 1210 P/U, an IH Scout II and an IH Scout 800 to tow 'em with.
