Old 04-27-2013, 01:16 PM
cub108 cub108 is offline
Default tractor let me down
the 108 i have with a 10hp motor will not start.
it is not getting any spark. i have tried a working coil, plug, and condenser. the points are new.(yes they are set correctly) what can be the problem?
started/generator
voltage regulator
someone please help
thanks
Old 04-27-2013, 01:37 PM
cubby102's Avatar
cubby102 cubby102 is offline
Sounds like its not getting juice to the coil itself. Look into your connections and check the wire from your switch t the v/r then to the coil
Old 04-27-2013, 03:15 PM
When you are cranking the engine over, do you have 12+ Volts going to the Ignition Coil..???
Old 04-27-2013, 04:39 PM
how do i check the coil for 12 volts?
in detail please. i put the red prong to the +of the coil and the - into the coil tower where the plug wire goes. did it with key in the on pos and the starting pos. both had 12+ volts. was this correct?
i have put everything from a working tractor on the 108 and nothing. v/r, s/g, coil, condenser
could it be a bad ignition switch or the switch that the brake/clutch peddle pushes down?
thanks
Old 04-27-2013, 05:48 PM
With a VOM or DVM, using the DC Scale for at least 15V or more. The RED test lead goes to the positive ( + ) side of the Ignition Coil, and the BLACK test lead goes to the negative ( - ) side of the Battery terminal (or a known good chassis ground).
Old 04-27-2013, 07:19 PM
EarlJ's Avatar
EarlJ EarlJ is online now
Sounds like you have the vr wired wrong, I've done that more than once and cussed my machines only to find that it was wrench turner error..
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 04-27-2013, 08:09 PM
If the engine is cranking, then it won't be a clutch pedal safety switch or a PTO Clutch safety switch which is located up under the dash. If the motor is not cranking period, then it could possibly be one or both of these safety switches. At that point you will want to check the switch with an Ohm meter to see if it is working.
Old 04-27-2013, 08:26 PM
sawdustdad's Avatar
Just another thing to check. Sometimes new points contacts need to be cleaned with fine sandpaper to make sure you get good contact.
Old 04-27-2013, 09:38 PM
cubfixer's Avatar
cubfixer cubfixer is offline
If it turns over, but won't fire, take a jumper lead and go from the positive post of the battery directly to the coil. It should fire.
John
Old 04-28-2013, 10:30 PM
My first question is: If you don't know if the points are working/have power to them... How do you know they are set right?
I agree, this is the fastest and easiest way to make it run.
The fastest way to find out if there is power going to the coil is; connect your test light to the neg battery post and touch the point to the positive side of the coil and turn the key to the "run" position (the light should come on).
To see if the points are making contact; connect the clip on your test light to the neg battery post and touch the point to the neg side of the coil and crank the engine over, if the points are working the light will go off when the points make contact and on when they are open.
