Old 04-25-2013, 12:59 AM
DT466E's Avatar
DT466E DT466E is offline
Default Front spindle washers
On my 122 I have a mix match of washers that came on the front spindles. I have 2 that are thick and tapered and one is just a plain flat washer. I'm assuming that the tapered ones are correct. They are pretty worn out. I cant seem to find them listed anywhere. Any ideas?
Thanks,
Brian
Cub Cadet 122
Old 04-25-2013, 07:22 AM
Go here..... Parts Lookup
Select:
* Brand Name - ie: Cub Cadet
* Model - ie: 122
* From that menu - find 122 then select "Select Assembly"
* Once that sub menu pops up, select the area of the tractor you are interested in
Old 04-25-2013, 10:28 PM
DT466E's Avatar
I've looked there..problem is i cant find the washers listed anywhere
Cub Cadet 122
Old 04-25-2013, 10:54 PM
For what it's worth, in my parts book it is listed as: Washer 13/32" X 1-1/2" X 11 Gauge Part #736-0227.
Try going back to the parts look-up and looking at the listing for the RH Knuckle Assy. It isn't shown in the drawing but it is listed under the description of and part number for the RH knuckle.
I'll betcha anything, you won't find that size washer in any hardware store, but I'll also bet that a good heavy 3/8" fender washer will work just as well.
Old 04-25-2013, 11:16 PM
DT466E's Avatar
i see that now thanks! i guess i have to do a little reading not just look at the pictures!
Cub Cadet 122
