The steering arm on my CC cub is worn and I am not having any luck finding one .........even on Evil Bay.
And Patton Acres is sold out. I have shown the two different types below but my is the curved arm type and I don't see any way that the t-type could be used.........easily that is. Does anyone know if there is another part number or what it would take to adapt to something else. Not in an urgent need as it is worn a has some slop to it but other than that it can wait until I find something but just want to be prepared when it does need it. Also will need that Heim joint replaced as it is really sloppy, so going to take it off today and see if ACE has a replacement. Not sure of the thread size so I need to remove it to make sure that it is an exact match. I don't have power steering on either of my cubs.
Joe 1200 Puller[/U][/B] 1864 2072 with 54 Inch Haban Blade |
How about a simple bushing job?
Good idea Mike.
I would rather find a used one to do the bushing job on and then have it to replace ready to go. If I can find one for 20 bucks, it would be well worth it for me to do this in advance.
Researched all of the old posts on here and everywhere that I can find on the internet and I cannot find a place that has those HEIM joings for the steering arm. They are a 3/8" diameter rod and a 1/2/20 thread and cannot find anyone ....even McMaster carr that has any that are that particular size.
Help..........
Check my posts I changed out mine from McMasters. Get them on Epay also just search for club Cadet 1872.
Hey there Leadslingingdaddy, I checked your posts and found where you had worked the power steering rod ends but could not find anything for the steering arm.
This one is a 1/2 -20 female thread with a 3/8 hole that mounts to the pivot arm . That piece is hard for me to find. I could just put another cub part on there, just didn't want to jump to that if someone had found a better part. The cub part seems to be made out of just stamped metal and not a fully machined part.
