Old 04-16-2013, 10:48 PM
cubby102's Avatar
cubby102 cubby102 is offline
Default project "new '62 CCO"
Well with the temporary layoffs they just did at work I have finally got around to a few projects. I finally got started on my o that has been tore down in my shed for the last three months I've got 2 coats of school bus yellow on the frame and rearend now have had the entire rearend gone through and cleaned up got all the rust pits in the frame smoothed out. This is going to be a very long restoration as time and funds allow I will be replacing EVERY wear part on this my goal is to have a "brand new 1962" cub original with fenders 3 point spring assist and hopefully headlights and a grote. I still have a few more coats to go on before.I am done with these parts but I figure I might as well start a thread as I've been working on the frame for a week now to get it smoothed out. Here is the only pic I have of my progress as I forgot to take any during prep and primer ill be adding more as time goes on
Old 04-16-2013, 11:01 PM
greener14519's Avatar
greener14519 greener14519 is offline
Awesome! Sounds like a cool resto project. I'm subscribing so I can follow your work.
Looks great! Please keep the pics and updates coming.
Old 04-16-2013, 11:19 PM
cubby102's Avatar
Here's a pic of it before the teardown. Looks a lot better in the pic then it really was. The lo made a attempt at repainting but cut a lot of.corners
Old 04-17-2013, 12:07 AM
Glad you're getting back on to you project
Good luck, we'll be watching for sure.
Old 04-17-2013, 06:18 AM
Looking good!
It's going to look great when you are done!
Old 04-17-2013, 09:49 AM
ihcc104's Avatar
ihcc104 ihcc104 is offline
Sorry to hear you had a temp lay-off, but at least your getting around to projects! Keep up the good work! Nice progress!!
- Cory Sanderson
Old 04-17-2013, 10:42 AM
Sorry about the temp layoff. Your approaching this with the right mindset. If it needs it done do it. It will pay off in the long run reward you with many years of service.
Old 04-17-2013, 11:40 AM
cubby102's Avatar
Thanks guys I want to take this to shows as well as use it so even if it dosnt need it it is getting done. My budget is lower but that just means it will be a slower process. How hard is it to get clutch parts. I've noticed the o clutch is quite a bit different then the narrow.frames I'm still studying it.trying to figure it out
Old 04-17-2013, 11:49 AM
ihcc104's Avatar
Whats wrong with the clutch? You are right they are way different than NF's, but are VERY simplistic... not much to go wrong....
- Cory Sanderson
