Old 04-13-2013, 03:19 PM
ihc353s's Avatar
ihc353s ihc353s is offline
Default Cub cadet 128-Tank Problem!
Hi Guys,
i have a little Problem at a Cub Cadet 128, the Fuel Tank leaks, and the Rubber from the Fuel Vavle is bad.
Where can i get this Part, does someone have a Part Number, and is this the same Part as from the red CCC 782, (1984)?
Thanks for helping,
mfg Georg
I'm proud to be a German Cub Cadet 782 Owner!!!!
Old 04-13-2013, 04:48 PM
dale c. dale c. is offline
that is not the right tank for a 128 they have metal tanks,someone must have put a tank from a quiet line cub on it,models 1000,1200,1250,1450,1650.try the carter grunwald parts site for part #just checked part# for you 751-3008 superseded by part #935-0149 $5.45
Old 04-13-2013, 05:17 PM
Georg,
Dale C is correct, the 1x8/9 series tractors came with a steel tank. Looks like it is from the "Quietline" Series tractors. If that is the case, then...
The Part Number is 935-0149 Bushing. If you can not get it or find it in Germany, then the Sponsors listed at the top of the page will be more than willing to send you one.
Old 04-14-2013, 08:39 AM
ihc353s's Avatar
thank you yery much, i have it,
mfg Georg
Old 04-15-2013, 01:16 AM
How about putting an add for the correct tank in the wanted section here.
Surely someone here will give you a good deal on a good used correct tank.
