Thread Tools
Display Modes
I have a really nice 123 that I pulled the rear end on tonight to do some work to the drive-shaft.
I noticed that when spinning the hydro input shaft by hand, there is a rough spot in one place. It's not hard to turn past this spot but I can feel it when i spin it. It's kind of like a rough spot in a bearing. Is that what I'm dealing with? Should I be concerned? The hydro worked great I'm just wondering if I should continue to use it or swap it out for a different used one I have laying around? The other one turns smooth no rough spot. Any advice would be appreciated as I plan to put back together tomorrow evening.
John, PROUD OWNER ![]() ![]() ![]() |
Do you notice any change if you move the trunnion while turning the input?
![]() Quote:
i did notice the roughness is not just one spot its almost 1/4 around and the same spot every revolution. feels to me like a bad bearing but not sure. when i bought the tractor the po gave a an almost empty jug of hytran and it had a pretty steady leak. If the hydro was run dry at some point i imagine it could cause pretty quick damage? maybe i should swap to be safe?
It could be a bearing, the charge pump or the piston pump. If you have a better one I'd put that in unless you feel like opening up the one that you think may have an issue.
This is a thread I did on a pump and rear end you may want to take a look at to get an idea of what is involved should you wish to give it a shot. http://www.onlycubcadets.net/forum/s...ad.php?t=23229
thanks for the info. i think ill just switch it out until i get the time to tear it open and have a look
