Old 04-06-2013, 02:40 PM
macman81's Avatar
macman81 macman81 is offline
Default 1650 smoke from engine after shutdown. need ideas!!
im going through a newly acquired 1450 for my friend and i got it running but noticed smoke from under the engine tin after i shut it down. so i removed the engine and all the tin. not oil leaks anywhere except a little from the breather but i think thats kinda normal? cleaned the grass clipping off the flywheel and head and thought problem solved.
put it all back together does the exact same thing. i did notice its charging 17 volts so i unplugged the regulator thinking maybe the stator would get hot from overcharging. ran for a few more minutes hoping the airflow would cool it down. didnt help still smoking in my garage right now! its been like 20 minutes and no change. Comes out behind the carb and mostly the hole in the flywheel cover where the air cleaner hose hooks into.
the smoke smells like hot engine. not electrical or oil smell.
i have no idea what it could be any ideas??
John,
PROUD OWNER
Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow,
1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
Old 04-06-2013, 04:21 PM
CubDieselFan's Avatar
That is a odd problem, maybe someone will chime in that has seen that before.
Old 04-06-2013, 05:24 PM
Out of time? , Been messin' with the points??
Incorrect timing might make it run hot.
Old 04-06-2013, 06:15 PM
Hmm....interesting problem, especially if you cleaned it out already and don't see anything. I'd run some Marvel Mystery Oil through the fuel system and see if that helps at all. That is just a quick guess, maybe to free up something that might be obstructed....
Old 04-06-2013, 06:24 PM
I use Kaopectate after I use Marvel Mystery Oil for an obstruction, OH, you are talking about a tractor!!
Old 04-06-2013, 07:06 PM
macman81's Avatar
Points haven't been messed with but I should check the timing. Doesn't seen to run unusually hot. I'm hoping it could have been residue from the brake parts cleaner but I have my doubts
John,
PROUD OWNER
Old 04-08-2013, 12:59 AM
macman81's Avatar
i think the brake cleaner residue was the culprit. it was smoking the first time i ran it due to the grass clippings inside the tin. i didnt have time to tear it down and didnt want my house to burn down so i sprayed a whole can of non flammable brake parts cleaner on it to put out the "fire". it must have taken a few runs to burn off the residue but now it doesnt smoke any more.
thanks for your help guys!
John,
PROUD OWNER
Old 04-08-2013, 06:22 AM
Good to hear John!
Old 04-08-2013, 10:22 AM
Glad it wasn't anything major wrong.
Old 04-11-2013, 12:22 PM
macman81's Avatar
me too. i was afraid i smoked the stator
John,
PROUD OWNER
