Old 03-31-2013, 06:14 PM
maddog784's Avatar
Default 1864 Question
I am doing some research for my dad and am wondering if a sleeve hitch can be installed on an 1864. If so, does it use the pin/Frankenstien bolts method and what kind of lit rod would it take? Any complications such as the fuel tank location, etc.?
Thanks in advance!
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 03-31-2013, 06:48 PM
Don't know about a sleeve hitch but I know you can put a Cat 0 3 point on it.
Old 03-31-2013, 08:09 PM
I think you will have a problem with the fuel tank. You would have to pull the rear frame plate off and that would be another problem waiting to happen. If the funds are there, go with the cat 0 and a brinly adapter.
Old 03-31-2013, 10:47 PM
I'm with Todd's thinking on this.
Old 04-01-2013, 09:59 PM
maddog784's Avatar
Well, I appreciate all of the feedback. I guess I will have to explore some other avenues.
Much obliged!
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 04-13-2017, 10:00 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Bump bump bump bump bump bump
1- 1200 in pieces
1- 1864 in pieces
