Old 03-30-2013, 10:36 AM
dieselsmoke dieselsmoke is offline
Default 882 axle upgrade
Could someone list a few model numbers that would be a good swap to a super steer front axle? My 882 is in need of much tighter steering. Thanks
Old 03-30-2013, 11:30 AM
I'd look for an axle out of a 1440, 1641, 1863 or an 1864. The 1864 had power steering but I think the drag link will bolt up where PS cylinder did.
I used a 1440 axle on the 1210 I used to own. Bolt in swap.
Old 04-01-2013, 09:20 AM
Default Upgrade
Ok, thanks for the reply, I will keep my eyes open for one
Old 04-01-2013, 10:39 AM
Try the sponsors at the top of the page.
Old 04-01-2013, 06:33 PM
Frank1541 Frank1541 is offline
I am pretty sure that the Super front axle is narrower across the top. (looking down at it from above). If I remember correctly they are one quarter inch narrower than a standard Cub axle. So you would have to make up that difference to use one.
Old 04-01-2013, 06:48 PM
How about if you look at it from the bottom, up!!??
Old 04-02-2013, 08:49 AM
Well, as my wife would say, "right as usual", to which I say "its all a matter of perspective".
Now I wonder if the later cubs have a wider axle or if my brain has finally died.
Old 04-10-2013, 08:36 PM
What axle is that one? I dont recognize that tie rod setup with the pivot in the middle.
Old 04-10-2013, 08:38 PM
It is from a Super, being red I'd guess a 982
Old 04-10-2013, 09:18 PM
cub123's Avatar
cub123 cub123 is offline
Yup, it's from a manual steering 982, I kind of like the design on them because it puts little stress on the pivot pin in the axle when steering unlike spindle mounted drag link setups.
