Old 03-30-2013, 10:08 AM
Default HELP mower deck blades will NOT stop spinning
guys please help my cub cadet original mower deck has all new belts but when the tractor is running the blades keep on spinning when the mower is disengaged i tried one of the old short belts that goes on the 2 pullies but it didnt help i dont know what to do. please help, thanks
Old 03-30-2013, 11:52 AM
Mcamp Mcamp is offline
sounds like your tensioner on the deck is not moving far enough to take the tension off your belt. Mark
Old 03-30-2013, 01:51 PM
thanks mark how do i fix this
Old 03-30-2013, 03:37 PM
cnixon's Avatar
cnixon cnixon is offline
Theres a rod on the kick clutch that you can screw in or out. Put some lube on that center pulley where it moves back and fourth too.
Old 03-30-2013, 04:47 PM
ok thanks
Old 03-30-2013, 06:09 PM
ok guys i made a little progress i used CRC power lube on the slide plate and center pulley and took off the cast iron pedal cleaned it up and sprayed it with CRC , put it back and sprayed the adjustment rod, im letting it soak
Old 03-30-2013, 06:52 PM
Awesome news Nick! It's good your thinking about safety. Accidents suck.
Old 03-30-2013, 06:53 PM
i know, Duke, i sent you a PM
Old 03-30-2013, 06:54 PM
I sent a reply back at ya. Sorry I don't have the answer for ya.
Old 03-30-2013, 06:56 PM
Its ok, i will try my best to fix it
