Old 03-28-2013, 01:22 AM
thomas 1863's Avatar
thomas 1863 thomas 1863 is offline
Default 127 brake question
i have 2 127 cubs one when i press the brake it puts the hydro lever in to neutral like it is saposto but my outer when the trany is engaged whenn i try and press the brake i can get it to push down to put it in neutral it will go down if i disengage the trany could it just need a good oiling or what you guys think
Old 03-28-2013, 11:56 AM
cadzag72 cadzag72 is offline
I had a similar problem with my 125, solved it by spraying some white grease on the linkage. if you take the battery out and follow the shifter rod down through the dash tower, you'll see a wedge-shaped piece that should move when the brake pedal moves; this is what you want to soak. make sure to get both sides. sorry that I don't have any pictures of it.
Ian
Old 03-28-2013, 11:40 PM
Mr.Goffena's Avatar
Mr.Goffena Mr.Goffena is offline
The 127 is different then the 125. The 127 uses a few belleville washers and friction disks. When I was having a problem with my hyro lever being to stiff i soaked it with some WD40 but this made it too lose and it would just flop around. I ended up taking out the whole control linkage out of the tower and tearing it down and freeing it all up. But if the handle isnt to hard to move I would look at the neutral linkage on the hydro. my
