Old 03-25-2013, 06:40 PM
cubby102's Avatar
cubby102 cubby102 is offline
Default 1650 cooling fan
Has anybody ever used a metal cooling fan for the hydro like on the 123s for a quietline. Or would it even work I uavnt looked to much into it I just thought it might be a little more resistant to breakage. The one on my 1650 now is broken so I have to.swap it.eather way I also have both the plastic one and a metal laying here. What are your opinions
Old 03-25-2013, 07:02 PM
I know it's not quite the same but at least one of my 149's has the metal fan.
Old 03-25-2013, 08:27 PM
cubby102's Avatar
I'll probably end up giving it a shot. I just didn't know if it would push enough air to keep it cool while mowing. Any other ideas?
Old 03-26-2013, 12:06 AM
machinehead323 machinehead323 is offline
i need to replace my fan too. the last time i had the tunnel off there was a blade missing. the plastic seems very brittle. i do not know if the new ones are brittle or the plastic has just aged. i would say mine is the original, so if a new plastic one lasts 30+ years ill be ok.
1979 1650, #1 tiller with one extension, 90 degree box mounted, 3 point. 1961 4 digit bringing back to life. I have the mower and 3 pint for it. The 1650 is the fastest mower in the neighborhood.
Old 03-26-2013, 12:58 AM
macman81's Avatar
macman81 macman81 is offline
i've broke 2 brand new fans already. please let me know if the metal one fits!
John,
PROUD OWNER
Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow,
1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
Old 03-26-2013, 05:48 AM
Grampie Grampie is offline
Why are they breaking? What are they hitting? You're Hydraulic Lift Linkage? With the cover off the drive shaft, engine running, ( be careful ) work your lift lever and watch your cylinder and its linkage move. There's a part that hindges before it actually starts to lift your deck. (float) It can be locked in a streight position by moving the pin into the other hole.. I broke a brand new fan myself, thought I had it back far enough on the shaft but that hydro lift caught it , GONE! ( BE CAREFUL ) That cover is on there for a reason!!!!! The next new fan I bought I took a 1/4 inch off the tip of each blade with the bench grinder for clearence. Good Luck ! ( this was on my 149 )
