Old 03-18-2013, 05:17 PM
sfaulkner's Avatar
sfaulkner sfaulkner is offline
Default Front PTO
Is the front pto the same for a 100 as it is for a 108?
1963 Original
1965 100
1937 F20
It's all designed to blow our minds, but our minds won't really be blown
Old 03-18-2013, 05:49 PM
Yes & no.
The one on the 108 is the same, but if it is the brake style it will not work unless you switch out the thrust button.
Otherwise they are the same as they perform the same task, but the 108 is a heavier duty type for the higher Hp wide frames, 14 and 16 Hp.
Old 03-18-2013, 07:44 PM
This link helps understand the three different type mechanical PTO's.
http://www.onlycubcadets.net/forum/showthread.php?t=9
Old 03-19-2013, 10:14 AM
sfaulkner's Avatar
Thanks for the response. I saw one on ebay for a 108 and I need one for a 100. You guys always are a great help.
1963 Original
1965 100
1937 F20
