Old 11-22-2009, 01:02 PM
youngguyoldcubs youngguyoldcubs is offline
Default quick question
Both a 126 and 127 are both narrow frame tractors right? I bought a narrow frame plow and its still to narrow. thanks
Old 11-22-2009, 01:29 PM
mstetar's Avatar
mstetar mstetar is offline
yes there both narrow frames, however there are two types of narrow frame plows, the 70/100/71/102/122/123 had a bolt on type. the front mounts flare outward, this was so that it could bolt to the front mule drive or if the tractor didnt have a mule drive there were extention brackets that came with it so it would reach the frame and be the right width! the kind that you need for a 126/127 is a narrow frame quick attach, the front mount arms go straight up and have pins that go into the QA slot..... or your subframe could simply be bent.
check out my cub site
Old 11-22-2009, 01:57 PM
Awesome. Thanks guys I will try to track one down..
