front of the mule drive bracket never looked to be all the way back to the bolts sticking out of the frame, but it seemed locked up front and the mower worked.I followed the manual and removed the deck. as soon as the rear pins were pulled, the front mule drive bracket plopped off. After puling the deck out, i lifted it up, ans tried to lock it in (pushing down on the locking bar). It would shut, then pop open again...here are pics
![]() red shows where it locks on, pops open green just shows where the frame bolts on where the mule bracket slides over. to me it seems like it wont go back enough, but was working? here is a side shot so you can see if its all good in the rear ![]() thanks for helpin a newb ![]() |
The sides of the mule drive slide into the Frankenstein bolts on either side of the tractor, your mule drive is hung by the arrows in yellow. If it keeps falling off the springs are broken on the QA latch
it seems as if it wont slide back enough...
Got to get mad at it, works for me.
Donovan: 62' Original-fenders 63' 100R-K-321a,lights,creeper,electric lift 149-original paint, tiller, three point, duals, ags 1811Custom -M18-18hp kohler magnum, power steering and hydraulic lift with Three point and sleeve hitch. ---------------------------------------------------- Attachments:three-QA 42inch,42inch blade,one-38inch cast end, QA 44inch deck Brinly 12inch plow, 2x cultivators and x2disc Brinly Tool bar cub10: ![]() |
To lock the mule in place the bar sould be in the up position.
Yeah and if that doesn't help with the bar in the up position bolt it on. Mine is bolted on for added re assurance; I also bolt on my winter blade even though I don't have to; I'm not changing them every 5 seconds.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
