Old 03-08-2013, 06:13 PM
TommyK's Avatar
TommyK TommyK is offline
Default couple of questions
I have a couple of questions. How do you adjust a WF clutch if you install a midwest super cub heavy duty long release arm? So that there is .05 inch clearance between the throwout bearing and release arm? I know that for a stock release arm adjusting the brake pedal so there is 9/32 inch before resistance will give it the correct clearance. Is it the same when using the longer release arm? The other question i have is, has anyone bought the heavy duty pulling throwout bearing being sold on evilpay? If you have, is it better than a stock throwout bearing? Thanks
Old 03-11-2013, 12:37 PM
austin8214's Avatar
Get the throwout bearing from Kerber machine. It's cheap and easily replaced. And it holds up well.
