Old 03-06-2013, 12:56 PM
timbo2's Avatar
timbo2 timbo2 is offline
Default QA42A tension clip
Is this the correct way to use this clip?
It looks like it is there to keep the tension bolt from unwinding after you tighten the belt.
Thanks!
- Tim
Old 03-06-2013, 02:39 PM
I cannot find a reference to that clip in the qa42a manual. It looks like a previous owner add on.
Here is the link to the manual:
http://ccmanuals.info/pdf/QA%2036A%2...s%20Manual.pdf
Old 03-06-2013, 03:17 PM
timbo2's Avatar
Thanks Dwayne -
how would you lock that tension bolt in place? I have seen other threads where a hole was drilled and an extra bolt used to block it but wasn't sure.
- Tim
Old 03-06-2013, 03:29 PM
mortten mortten is offline
That is a factory item. It is not mentioned in the operator manual. It is part number IH-79631-C1, item 23 in the parts look up. Never saw one though.
