Old 03-03-2013, 11:07 PM
macman81's Avatar
macman81 macman81 is offline
Default Can a carburetor cause engine vibration??
hi. just brought home my 122 today. it ran great at mid rpm and up but idled like garbage when i bought it. so i go to clean the carb and its a stinkin walbro. so i swap it out for a #26 kohler carb that appears to be off a quietline since it has black paint on it and the newer style throttle shaft.
long story short now it runs like a swiss watch at all rpms but i swear it vibrates much more than it did before the carb swap. what gives?
throttle shaft has some play but not any more than the walbro i took off. adjusting the fuel mixture makes no difference.
is this possible or did i dream it up?
any input would be kindly appreciated.
John,
PROUD OWNER
Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow,
1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
Old 03-04-2013, 12:05 AM
sawdustdad's Avatar
I've never heard of a properly set up carb CAUSING vibration, unless it causes the engine to run faster and vibrate MORE. I bet it's just your imagination.
