Old 02-28-2013, 07:47 PM
CadetTY's Avatar
CadetTY CadetTY is offline
Default input on 1000
I found a 1000 quiet line for $300. The Seller says it runs but is stuck in reverse. Body is in great shape for its age. What do you guys think?
882 diesel, x3 ih 582, 73 124, x2 82 seriers pullers, 1686 16hp puller
Old 02-28-2013, 07:59 PM
I think you will get a sore neck driving it.
Up to 530 and counting...
Old 02-28-2013, 08:26 PM
cubby102's Avatar
cubby102 cubby102 is offline
i never had a complaint about my old 1000 other then i dont care for the iso mount setup. the rear could be a easy fix or simply swap out the rear , for a 10 horse that thing did everything i ever asked of it with the 44 inch deck. never once gave me a problem
Old 02-28-2013, 08:35 PM
IF, it is stuck in reverse, it has NOTHING to do with the rear end. I would venture to say, it is one of the Hydro Check Valves.
Old 02-28-2013, 08:51 PM
CadetTY's Avatar
It has a standard 3 speed in it
Old 03-01-2013, 02:56 AM
cubby102's Avatar
Must be havin a brain stink. 1000 is gear drive
On another note if it runs well with no.smoke I.say buy it
Old 03-01-2013, 06:31 AM
Could be a simple fix but you won't know till you pull the shifter and take a look. Worst case you can probably part it out to get your $300 back if you have to.
Old 03-01-2013, 07:37 AM
Oppps............My Bad.............was thinking Hydros. Disregard my comment....
Old 03-01-2013, 08:14 AM
rusmart rusmart is offline
I bought my original with some rusty shift mechanisms. Wouldn't go into 2nd and 3rd til the PO forced it. Ended up having quite a bit of water in the tranny. Went through the transmission and it cleaned up pretty good. Spend some time sanding and greasing the shift rods. Works well now.
The only 1000 I've seen had a horrible paint job (completely yellow with tons of overspray), missing side panels, had a craftsman snow plow welded on the frame, frozen engine, but it had a complete tiller package and creeper gear. Guy wouldn't go down past $750. I'd like the tiller, but not really interested in the tractor.
Russell
Edit: clarity
Russell
Cub Cadet Original w/ 3pt
Cub Cadet Original w/ fenders, creeper, & 3pt
Cub 100 w/ 3pt
Cub 125 w/ 3pt
NF Blade, cultivator, brinly plow, 38" & 42" deck, disc, tiller
Old 03-01-2013, 08:32 AM
CRS kicking in? Just had to bust
