Old 02-27-2013, 06:42 PM
CHESTERSCUBSC CHESTERSCUBSC is offline
Default Loose oil filler tube on 1650
I am new to this forum and would like some help on a 1650 that I am starting to work on. I am in the process of doing the mods for the engine mount bracket and also installing the new oem mounts. I did notice when I pulled the the engine that the oil filler tube is loose where it goes into the crankcase. What is the fix? Is it pressed in the case or installed with loctite or some other method. When I pulled the tube out I did not notice any o rings of seals.
Could use some help of the fix for the loose tube.
Thanks Ron
Old 02-27-2013, 08:08 PM
IIRC, I believe the oil filler tube is a pressed fit into the crankcase.
Old 02-27-2013, 08:42 PM
Bushman Bushman is offline
I had the same thing on an Onan and was advised to use Locktite or oil resistant sealer. Just clean it up very throughly and give it a go. Might be worth it to rough up the tube surface and lightly scratch the inside of the tube hole to give some additional bite.
Old 02-28-2013, 07:10 AM
There are also ways also to enlarge the tube.
Locate a piece of bar stock about the same size as the tube and slip it inside then using a small #1 or so hammer,go about hitting the tube while holding the bar in a vice, thus expanding the tube with every blow,working your way around the tube,(it takes a while)
Sometimes long sockets are handy for this.
My perfered method it to turn a piece up in the lathe, just a bit larger and maybe tapered ever so slightly so it is a slight drive fit thus expanding the tube that way.
We are only talking maybe a half to one thousand here,
but most folks do not have access to a lathe.
Old 02-28-2013, 09:10 AM
rmunro's Avatar
rmunro rmunro is offline
My 1450 has same deal. Exactly. Some oil was coming from there. I gave it a light squeeze in vice. Applied permatex gasket make 2, and lightly tapped it in. Then I tried securing it with a clamp, around the filler, a spacer, and a longer bolt through an existing bolt hole in the tins. Now, I haven't run mine at all really since because it leaks oil somewhere else a ton, so don't know how well this worked on the problem.
Roger,,109,1450,1210
Some Days all You Can Do Is Hang On!!!
Old 02-28-2013, 10:17 AM
Thanks guys for all the responses. I believe that if I try a combination of these methods it should fix the problem. I am thinking that the excessive vibrations from the bad ISO mounts probably caused the problem, so if I take care of that issue it should help out also.
Thanks again Ronc
Old 02-28-2013, 10:46 AM
rmunro's Avatar
I'm sure the vibration was a factor. In mine too. There are no ISO mounts in mine. I think they may have messed up the oil pan buy trying to bolt solid with no spacers.
I bought this tractor, and a 1210 in January. In both cases the "repairmen"(term used loosely) have been the tractors worst enemy.
