Old 02-26-2013, 09:13 PM
fourinchdragslicks fourinchdragslicks is offline
Default Quietline repower
Has anyone done a quietline repower that keeps the tins and ideally the front pto?
Old 02-26-2013, 09:22 PM
Darrell Darrell is offline
I sent a PM. Thanks , Darrell
Old 02-26-2013, 09:40 PM
IH Cub Cadet IH Cub Cadet is offline
What are you thinking in terms of a repower, a twin cylinder or something else?
Sounds like an interesting thread.
Good luck,
Bill
IH Cub Cadet 109
IH Cub Cadet 126 (2)
IH Cub Cadet 149
IH Cub Cadet 1650
MTD Cub Cadet LTX1042
Old 02-26-2013, 10:50 PM
Not a single cyl. Something 25 hp or less to stay within the hydro design limit.
Old 02-26-2013, 11:41 PM
macman81's Avatar
macman81 macman81 is offline
i am also interested in doing the same thing. I'm building a quietline to be on snow thrower duty and the extra hp could be handy once in a while.
John,
PROUD OWNER
Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow,
1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
Old 02-27-2013, 08:37 PM
I am wanting to use mine as a mini tractor, and I know I have a rebuild coming up (pretty severe oil leak/ oil burning) I am just looking to see if anyone has done any of the legwork I would have to if I were to repower with more power. Probably the biggest reason for wanting a repower is to kill as much of the vibration as possible.
Old 02-27-2013, 09:04 PM
Bushman Bushman is offline
Just my 2 cents. Seems a guy could do all of the noise isolation and get a good rebuild for a whole lot less bread than stuffing a non stock engine into a Quietline. I would think it would be tough to find a V-twin that would fit in the engine bay with side panels as is. That series of tractors was designed with a Kohler single in mind. Just think of the Cub Cadets that proceeded the Quietlines. Any of the twins had a larger hood and engine bay.
I do not know if this is even a consideration but, a K-361 is an 18hp single that would fit with minor hood modification at most if the overhead valves stick up too high. Get a new set of Iso Mounts and a good K-361 and you would have something.
My 1450 was a rattler when I bought it. After some casual and enjoyable fiddling it purrs now.
Old 02-27-2013, 10:42 PM
OldSchool81's Avatar
OldSchool81 OldSchool81 is offline
You nailed it bushman.
Old 02-27-2013, 10:58 PM
I dont feel that the k-341 makes too much noise, I like the look of the quietline with the side panels on. I like stock stuff, but I also like things nicely modified with a "factory" appearance. In this case, I would ideally like the look of the quietline but with 20+hp, and starting with less vibration than the k series. I replaced the iso mounts and did the cradle mod on my 1650 and it made a tremendous difference from how i received it, but the engine now needs a rebuild. I am exploring options and kicking tires. just want to see if someone else has done it and how.
Old 02-28-2013, 08:35 AM
These guys sell a re-power kit but the side tins won't fit and the fuel tank is also an issue.
http://www.smallenginewarehouse.com/...tegory=1709551
