Old 02-25-2013, 06:14 PM
Cjbdvm04 Cjbdvm04 is offline
Default K301 main bearings
Just a little info regarding the k301 (and likely other k series engines). After tear down I found the races of the main bearings were severely pitted. After doing some research I found the the oem kohler main bearings are made by skf and it is a standard bearing: 6300/c3 or 6300/jem. The c3 and jem suffixes are essentially identical and interchangeable. These bearings can be found on epay or other bearing distributors for a fraction of the cost ($20-30) of the oem kohler bearing ($100). Hope this helps.
Old 02-25-2013, 06:15 PM
Sorry. Made a mistake, it's a 6308, not 6300.
Old 02-26-2013, 08:51 AM
rmunro's Avatar
rmunro rmunro is offline
I assume you're talking crankshaft front and rear bearings???
Roger,,109,1450,1210
Some Days all You Can Do Is Hang On!!!
Old 02-26-2013, 10:25 AM
Yes. Sorry for not clarifying.
Old 02-26-2013, 10:34 AM
rmunro's Avatar
Not a problem. Thanks for info.
