Thread Tools
Display Modes
I was wondering where I can buy new ISO mounts and hardware for a cub 1650?
Thanks! |
I would recommend new mounts from your cub cadet dealer.
There has been lengthy discussion on this and though they are pricey you will be happy in the end with them. My 0.02! |
![]() Quote:
If you go aftermarket rubber, you might not like added vibration that they present. |
I agree with the others. Get them from Cub Cadet, and you'll be happy with the results.
One thing you can do to save yourself some $$'s is check to see if your top ISO mounts are un-damaged. If so, you can re-use them on the bottom and in doing so - not have to buy a set of 8.
Also, be sure to do the cradle mod too. Good luck, Bill
IH Cub Cadet 109 IH Cub Cadet 126 (2) IH Cub Cadet 149 IH Cub Cadet 1650 MTD Cub Cadet LTX1042 |
![]() Quote:
I bought a set for my 1650 from ccspecialties. Cost $80 for the four mounts but I'm told it will be worth it.
![]() Quote:
The reason you can reuse the top ones is that the bottom isolators are the ones that get crushed badly. Many times the top ones are unhurt and can be reused. Also, don't forget the two snubbers at the front of the engine mounts. Mine were crushed as bad as the 4 bottom isolators. Just asking. Thanks! Bill
Bill,
I am just going to guess here, but I am going to guess that the ISO mounts to which you refer are not the Cub Cadet OEM mount that is currently being produced. The current OEM ISO mount has no interchangeable parts. The bottom mount and top mount are completely different and cannot be inverted. I am told that the current OEM mount kit is a vast improvement over previous models. My guess is that you are referring to either non-OEM stock or very old OEM stock. Perhaps someone has a copy of the assembly instructions for the current OEM ISO mount kit that could be posted here. Brian Wittman |
I agree, the current CC/IH OEM mounts are not interchangeable, the two parts (top and bottom) are completely different and would not interchange properly. I suppose you could do it, but it would be a kludge and maybe worse.
