Old 02-23-2013, 07:53 PM
old149 old149 is offline
Default hydraulic pump from 122
I put an extra pump from a 122 on my 149 for my front blade. The pump don't work. It is on the same side as the 122 but is their a rotation problem?
Any help would be appreciated.
thank you old 149
po3jo7@yahoo.com
Old 02-23-2013, 08:33 PM
fourinchdragslicks fourinchdragslicks is offline
Rotation would be the same, has the pump been purged of air? Why not just tap the existing lines and add another valve?
Old 02-23-2013, 09:25 PM
Yes, the rotation is correct.
Is this a known good pump?
What kind of fluid did you put in the pump?
You didn't overfill it did you?
Old 02-23-2013, 09:58 PM
cub123's Avatar
cub123 cub123 is offline
I think because the pump is upside down it might not be getting fluid Especally if it only has the recommended amount of fluid.
Old 02-23-2013, 10:57 PM
LMAO, shoulda put my glasses on and looked closer at the pic.
Cub123 is correct, unbolt the pump, turn it over in the bracket, rotate the can and it stands a much better chance of working.
Old 02-24-2013, 07:42 AM
IF the Hydraulic Pump were mounted in the correct location, the Drive Pulley on the Flywheel end of the engine, would be a lot larger in diameter. Thus, spinning the pump at a higher RPM, would create the needed pressure, to work correctly.
Old 02-24-2013, 07:56 AM
It appears you are running approx a 1-3/4 to 1 reduction, try getting it so the suction inlet is on the bottom and see where you are @ as you are sucking wind now.
But I'm thinking like Roland, that it may need to be run faster to work,--- but you might be lucky and does what you want, just slower.
No harm in trying.
Old 02-24-2013, 10:39 AM
Muzzy Muzzy is offline
With the pump upside down like that it cant pick up any fluid. The inlet for the fluid is on the bottom of the pump. The way you have yours the inlet is at the top. Also, when you turn it over make sure that you rotate the fluid can so the filler is about 2/3 up on the side. The can should only be filled 2/3 full. There's very little that can go wrong with those pumps as long as they're not leaking. I would'nt worry about the pulley. Try it first.
Old 02-24-2013, 12:11 PM
Ask Allen what happens when one is over filled. I should have gotten him a new sock.
Make sure the fill hole on the pump is at the 2 o'clock position so you can fill it to the correct level.
Old 02-24-2013, 03:29 PM
LOL, I also know what happens when you overfill one.
First, you have to call Thing 1 and Thing 2 to come help clean the mess up...
