Old 02-18-2013, 08:02 PM
dieselman1 dieselman1 is offline
Exclamation 127 hydro fix
i have a cub cadet 127 and when i have the trans in neutral the tractor moves forward how can i adjust the trans so that when the tractor is in neutral the tractor does not move?
Old 02-18-2013, 08:59 PM
TheSaturnV's Avatar
I know this info is here on OCC, but heck if I could find it.
So, from the Cub FAQ:
http://cubfaq.com/neutraladjust.html
Old 02-18-2013, 09:03 PM
sawdustdad's Avatar
There is a procedure in the service manual. I need to do the same thing with my 149. You block the tractor's rear wheels up off the ground (jack stands), remove the tunnel cover and adjust the linkage. I've read the procedure, but it's hard to follow due to the terminology. It's probably really simple once you see how to do it. Hopefully someone who has done it will reveal the secret to success.
Old 02-19-2013, 11:47 AM
It's harder to do on a 127; no tunnel cover to remove here.
Old 02-21-2013, 02:52 PM
thank you for y'all input i will give that website a try and i will let y'all know how i make out.
Old 03-17-2013, 04:34 PM
I fixed my hydro problem and now it doesn't move when its in neutral.
Old 03-17-2013, 05:43 PM
Great news! Glad you got it fixed.
