When I got my 124, I noticed that the front axle had a weld on the left side. I idin't think much about it, and I have used the tractor hard over the summer and winter puching dirt and snow. After doing some reading and noticing that the axle is cast iron, I am thinking maybe I should replace the front axle. I do know that welding cast iron can be difficult. Any recommendations? Do you think this axle may be OK or should it be replaced?
John Proud Owner of a Model 100 and a Model 124. A homemade cart, 2 x 42" mower decks, a 38" deck, a 42" front NF blade, and a lawn sweeper! |
John, trust me when I say that won't hold.
I've had the same PO mod fail on me before.
It can be welded but you should be able to find a replacement for less that it would cost to weld it.
Good advice. I'll start checking with our sponsors.
I'd definitely replace it, John.
If your a good welder you can use nickel rods to weld it.
Again thats if your a good welder and own a good welder, or just replace it.
Doug Original , 100 , 125 , 582 ![]() ![]() ![]() ![]() West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
I have always wonder how you could break one like that? Ram it into a tree at WOT.
![]() Every one I've seen break has broken in that same spot. |
I don't really understand how in the world it would break either. That's nuts, probably someone doing something they weren't suppose to do.
- Cory Sanderson -~~- Cub Cadet 104 -~~- Cub Cadet 104 -~~- Cub Original -~~- Cub Lo-Boy 154 -~~- |
I weld for a living and like 4Speed said you would use Nickle rod. To fix that properly would be rather time consuming and like already mentioned should probably just be replaced. Most people when they weld cast dont do it properly. In order to get the strength out of it you have to "v" both pieces almost to a point. Then what you actually do is tach it in place flip it over run a bead then flip it back over and grind until to get into the bead you just laid. Then the welding begins!! You cant just weld the crack it will never hold. Also with cast depending on the room you have you can take a piece of flat stock and place over your repair spot and weld it on for even added strength. Good luck with it.
Years ago I was looking at a used Ariens GT 18. Noticed the front axle was welded and asked the seller want happened. It seams the dealer picked up the tractor for its yearly maintenance and when delivering it, the ramp slipped and the tractor did a nose-dive off the truck into the concrete. The driver went over the steering-wheel and hood, face first into concrete. He received a lot of reconstructed surgery to make his face right again. Make sure those ramps are secure.
Bought the tractor and ran it 15-20 years mowing and snow-blowing without a problem. But if you do not know the welder, it's a roll of the dice. |
