Old 02-16-2013, 06:45 PM
Cjbdvm04 Cjbdvm04 is offline
Default Oil pan and valve tappet question
I have a 127 with a k301as. Just got done tearing down the engine and found that the oil pan has a crack where a rock must have hit the deep sump portion near the drain plug. I've been looking at deep sump pans for the k301 on epay and each has subtle differences. Will any of these deep sump pans fit the k301 block?
Also, I noticed that the bottom of the tappets appear scored/pitted. Is this a problem and, if so, where do I find replacements?
Old 02-16-2013, 07:12 PM
The k 301 321 and 341pans are the same.You want a cast iron one, the aluminium ones tend to get cracks/stripped out mounting holes.
You can put and ad for your needs in the wanted section.
Up to 530 and counting...
Old 02-17-2013, 10:33 AM
cmatthew's Avatar
cmatthew cmatthew is offline
replace the tappets while you are in there. check out the sponsors on this website. they should have what you are looking for.
CC 123
402c Sickle Bar, 48" Mower Deck
QA42A Snow Thrower, 42'' Push Blade
IH Back Blade and Rake
Brinly Seeder/Aerator
Brinly Lawn Rake
Brinly 10" Moldboard,Brinly Cultivator, Brinly Disc
