Old 02-10-2013, 11:09 AM
ssechrist ssechrist is offline
Default Carb bowl gasket
Hello everyone, I got the removed and all cleaned up. It had some varnish in the main jet completely clogging it. Now I'm ready to install the carb but I haven't had any luck finding gaskets. I can make the mounting gasket but I'm needing advice on the bowl gasket. I was wondering if an O-Ring would work?
I think the old gasket will still work I just wanted to go back new. Thanks in advance for any advice or suggestions.
Old 02-10-2013, 11:53 AM
All you have to do is walk into any Cub Cadet or Kohler dealer and buy a carb kit, which you probably need anyway if the carb was all gunked up.
Old 02-10-2013, 12:02 PM
Yup, Cub Cadet/IH dealers sell them. IMO when you take apart a carb it needs to have new gaskets/seals installed cuz the old ones leak.
Old 02-10-2013, 06:10 PM
You can do what you like. I've re-used the bowl gasket quite a number of times on various K-series Kohler engines. You can buy them separately from a kit or used to anyway.
Old 02-11-2013, 01:09 AM
machinehead323 machinehead323 is offline
i got mine from a kohler dealer in town, though my local sears carried them, as well as john deere dealer, and napa. i got teh whole rebuild kit. like $13
1979 1650, #1 tiller with one extension, 90 degree box mounted, 3 point. 1961 4 digit bringing back to life. I have the mower and 3 pint for it. The 1650 is the fastest mower in the neighborhood.
