Old 02-08-2013, 08:58 PM
gillis51 gillis51 is offline
Default Hydro pump grinding sound
Just finished up my 149 Resto mod. Didn't touch the hydro pump other than add auto relief valves and completely drain fluid from the system.
Problem is when the tractor is turning over i can hear what sounds like a grinding noise that sounds like its coming from the hydto pump. If I start it quickly with the wheels elevated I don't hear the grinding but have inconsistent wheel rotation. I'm sure the linkage needs to be adjusted.
I replaced the hytrans fluid and filter.
Any suggestions? Could it be that I need to prime the pump? If do how do I do that.
Old 02-08-2013, 09:43 PM
thomas 1863's Avatar
thomas 1863 thomas 1863 is offline
i get the same sound on my 123 if its not in neutral all the way i would say the hydro pump is just trying to run when you start it adjust the linkage it should be fine
