Old 02-07-2013, 10:05 AM
cubby102's Avatar
cubby102 cubby102 is offline
Default junk in my O rearend
Anybody got any ideas on how to get this stuff out it almost looks like it came off the bottom of the shift plate as the rest of the parts are clean but I really don't want to completely dissassemble the rear at the moment as everything is tight and works well but really want to get this stuff out. any ideas would be awesome and ill start a thread as I get further along on the resto as its moving along very slowly
Old 02-07-2013, 10:11 AM
Maybe fill it with Kero or Diesel fuel and then go at it with a paint brush? Drain it out, filter the fluid and repeat until it's clean.
Old 02-07-2013, 10:17 AM
cubby102's Avatar
I was thinkin bout putting it in my parts washer but wasn't sure if the diesel would eat away at the input shaft seal or not. And use the sprayer to wash it out I wouldn't let it soak as none of the stuff is stuck on I can wipe it with my finger but its.really chunky
Old 02-07-2013, 10:27 AM
sawdustdad's Avatar
that's what I would do. I don't think seals constantly exposed to oil would be adversely affected by another petroleum product. What does the parts washer use as a fluid?
Old 02-07-2013, 10:50 AM
cub123's Avatar
cub123 cub123 is offline
I used diesel when I had my 106 trans apart, no trouble so far.
Old 02-07-2013, 11:40 AM
cubby102's Avatar
That sounds good then ill just use my washer. Sawdustdad I use diesel in it. Mainly because when its pretty well dirt I filter it and use it to heat my shed
Old 02-07-2013, 12:38 PM
cubfixer's Avatar
cubfixer cubfixer is offline
What kind of stuff is it? It looks like metal filings to me, but I can't tell fom the picture. Is it grainy or more like mud?
I would think that diesel would be OK to use to clean it out and not hurt the seals. If you had a recirculating parts washer going into the rear end, then a filter screen across a bucket so that the fluid would flow back into the bucket, and pouring it back into the washer might be handy.
I'd try to jack up the rear, wash a lot, then turn the gears a little, wash a lot, and keep turning and washing til it is clean.
Good luck!
John
Old 02-07-2013, 12:52 PM
cubby102's Avatar
It's like a dirty muddy rust looking gunk. Not real thick just flakey. It has a bunch of it on the bottom of the shifter plate so what I see in there might have fell off while I was wrenching. The rear has both axle tubes off and is seperate from the tractor so if I hang it by my cherry picker over top my washer I think.it'd be ok. The pump for the sprayer in the washer has its own filter I'm just worried about getting this junk down into important and expensive parts
Old 02-07-2013, 02:02 PM
Donovan M.'s Avatar
Looks like my original when I got it. I just cleaned it in a parts washer
Donovan:
62' Original-fenders
Old 02-07-2013, 03:24 PM
sawdustdad's Avatar
I think that's already the case, right?
