Old 01-25-2013, 08:22 PM
rrhines rrhines is offline
Default 782 Dash Restore
Guys-
I am doing a repaint on a 782, and I would like to freshen up the dash. The raised silver lettering for the controls has worn off in places, making them hard to see. It looked crappy, so I repainted the whole thing black. I would like to get it back to more of a factory look. Any good ideas out there for restoring the lettering?
Thanks
Old 01-26-2013, 01:57 AM
save_old_iron's Avatar
save_old_iron save_old_iron is offline
Easily done with common products available at your local auto parts store and craft centers.
Clean the dash thoroughly with a plastic scrub brush. Use dish washing liquid in clean water and clean the old dash of all residues.
Inspect the raised lettering. If any letters or symbols are damaged, the "smushed" areas can be nudged back into shape with the tip of a pair of needle nose pliers or similar tool. Heating the damaged area with a hot air gun may help get it right without further distortion. Any plastic hairs can be cleaned away with an Xacto knife.
Several manufactures sell automotive quality vinyl dye in gloss or satin black. Spray on a few light coats of the vinyl dye and the dash will spring back to life.
http://www.summitracing.com/parts/smm-15243/overview/
http://www.vhtpaint.com/products/vinyldye/
Once the dash has dried, use a silver paint pen from a craft store to lightly wisk over the top of the lettering. A large chisel shaped tip on the paint pen works better than the fine pointed tips. Flat chisel tips glide over the top of the letters without dripping paint down the sides of the raised letters / symbols.
Take your time with the lettering. Do not try to get the letters covered in one coat. Apply several light coats and buildup to the final finish. If the tip of the paint pen accumulates too much paint, dab the tip in a paper towel and remove 80% of the paint. Leave just enough on the tip just to dry brush the paint over the lettering.
Once all the paint is dry, you may want to mist a matte clear coat over the final finish to protect the work.
Good prep of the old dash is critical and having patience to allow the paint to dry will prevent issues when you go to apply the silver. Go slow and you will have show quality results.
I have done several dashes for older Wheel Horse tractors. The difference is truly remarkable.
I'll post a few before and after pics later.
If you do not learn something new every day ... you are not paying attention !
Old 01-26-2013, 03:13 PM
Thanks Old Iron,
I didn't know paint pens even were available. Great tip.
Thanks Again.
Old 09-24-2013, 01:50 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
That is awesome!! gunna do this to my 1864. Thanks from mee too!
1- 1200 in pieces
1- 1864 in pieces
