Thread Tools
Display Modes
A guy wants to trade me this Cub for a go cart I have. I am going to do it, I know him and he said the tractor ran until he got a gas leak in the tank. That isn't an issue. What is is the tractor is labeled a 147 yet it has a stick transmission. Were there 147's built with 3 speeds? If not can you help me ID it by the photo? (I don't have access to the serial # yet, but will in a few days). Thanks, Jason
![]() cub147 by ramman16248, on Flickr |
It looks like a frankencub! The frame suggests it's a 147 due to the cut outs where the engine flywheel is (and larger 14HP flywheel engine) and I'm guessing a PO (previous owner) had a problem at one time with they hydro transmission and put in a gear drive.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
Its hard to tell, but I would say it is a 1x6 series... either a 106 or 126 depending on the size of the engine. Looks like someone swapped the decals/hood & dash at some point. And no 147 were strictly hydrostatics.
- Cory Sanderson -~~- Cub Cadet 104 -~~- Cub Cadet 104 -~~- Cub Original -~~- Cub Lo-Boy 154 -~~- |
It has a 147 frame from what I can see but, the standard is'nt right. Looks like half 126 half 147.
Ok, So hypothetically, if someone did change the rear end out, it "SHOULD" work the same as far as mower etc goes. Just the clutch and rear is swapped possibly?
Does the dash have a hole in it for a hydro shaft?
That is a 147 since it has the notched frame and correct hoods and fenders. I agree with drglinski looks like someone just put a gear drive tranny in it.
Adam Current Workhorses: 1977 1650, Sleeve hitch, #2 tiller; 1985 782, QA 42A snowblower, 50'' deck, 42'' blade, Ags, IH Wheel weights; 197? 1250; 1976 1250, hydraulic lift, 44'' deck, 54'' blade (currently needing a engine) Current Projects: 1970 107, Sleeve hitch, 42'' deck, Tri Ribs, 8'' Brinley Plow Family owns over 30 tractors, 7 combines, 2 bulldozers, 2 mid size trucks, 1 semi, too many truck and scouts to count including parts, and 3 pulling tractors. All vintage IH. |
the fender pan doesnt look correct for it.
Doug Original , 100 , 125 , 582 ![]() ![]() ![]() ![]() West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
The fender pan looks just like the one on my 147.
It's a 147 someone has put a three speed in, the electric lift has also been replaced with a manual lift. A gear drive 14 hp NF sounds cool
149 with kwik-way loader,1772,two 1782 super smokers, 982 SGT w 54" haban blade,60" haban deck, 50in deck cat 0 3 point, brinly cat 0: blade, plow(3), disc.123,hydro lift. 61"O" Brinly single row planter,brinly cultivator,#2 trailer,brinly 10 inch plow,3 42 inch blades,Model #1 Tiller with extenstions,haban sickle mo. 106w/ags and hydro lift. ![]() |
