Thread Tools
Display Modes
I'm in the process of a rebuild of my 127. I got the PTO off successfully and realized the bearing was very rough while rotating so I figured replacement was in order. I could see that someone had messed around with the bearing as the punch hole was all boogered up and oblong with burrs. The collar had the long set screw with lock nut. The locknut was very loose and came off with my fingers. I put the Allen key in the set screw and just barely applied pressure when the exposed portion of the set screw snapped off. The remaining portion has no remaining "hex" for the Allen to grab. Suggestions? Thanks.
