Old 01-25-2013, 08:57 AM
Donny Curtis's Avatar
Donny Curtis Donny Curtis is offline
Default Found a 1250
Had a guy call me on a 1250, went to look at it, looks good, he has had it for almost 5 years and never got it to run,has deck in good shape, it is clean real clean, wanted $300 for it what you think
Donny
Old 01-25-2013, 09:14 AM
rmunro's Avatar
rmunro rmunro is offline
Don't know about your neck of the woods, but here in Canuckland that would be a deal. Tractor looks good.
Roger,,109,1450,1210
Some Days all You Can Do Is Hang On!!!
Old 01-25-2013, 09:25 AM
Default 1250
Looks good and solid, just not sure what I going to find on the cranking part, could be little thing, just not firing he said,but he has had it for 5 years is what has me wondering never got it to run, just don't what all he has done to get it to run.
Donny
Old 01-25-2013, 09:37 AM
cadzag72 cadzag72 is offline
i don't know a whole lot about quietlines, but to me 300 is too much for a non-runner.
Ian
Old 01-25-2013, 10:23 AM
As long as it has some compression, spark, and is getting enough fuel it'l make some kinds of noises
I'm sure it will be fairly easy once you take a look at it. $300 is a good price for one in that good of shape.
Old 01-25-2013, 01:20 PM
bkw3614 bkw3614 is offline
My guess is that is is something simple to make it run. If you can turn the engine by hand, it should go. You may have to do several things to get it to go, such as completely clean the gas tank and carburetor, change the coil, points and condenser, change the spark plug and plug wire. You may need to check the valves to be sure they aren't stuck and see that the push rod to the points isn't bent. The wire from the coil to the points may be shorted somewhere. Even the ignition switch could be bad.
After you get it to run, be sure to check the ISO mounts, replace as necessary, and do the engine cradle modification.
The 1250 is a nice cruising machine. This one looks nice and well-kept. If you can get it for less, by all means, do so, but I would take a chance on it.
Old 01-25-2013, 01:50 PM
Default 1250
Well I turned it over to a buddie of mine, he is going to go get it this weekend, If it was a three speed I would have gotten it the other day, but it is a nice Cub.
Donny
Old 01-25-2013, 01:53 PM
It's a good ballpark price IMO. Deck being included is good as well. Hopefully it's something small and you can fix it up for cheap.
Old 01-25-2013, 02:12 PM
Nice 1250, Donny! You did real well on it.
Old 01-25-2013, 03:25 PM
OldSchool81's Avatar
OldSchool81 OldSchool81 is offline
No shame in 300.00 even if it doesn't run. Hope for something small. That baby looks great.
