Thread Tools
Display Modes
Will a hydrolic lift off of a 1711 fit on a 1250. I know the valve handle will need to be changed any thing else.
Donovan: 62' Original-fenders 63' 100R-K-321a,lights,creeper,electric lift 149-original paint, tiller, three point, duals, ags 1811Custom -M18-18hp kohler magnum, power steering and hydraulic lift with Three point and sleeve hitch. ---------------------------------------------------- Attachments:three-QA 42inch,42inch blade,one-38inch cast end, QA 44inch deck Brinly 12inch plow, 2x cultivators and x2disc Brinly Tool bar cub10: ![]() |
They are quite a bit different, cylinders are different lengths, as well as how they mount I believe. Plus if the 1250 doesn't have a ported pump you will need it as well. I'm sure it could be done, I think you would have to drill the frame for the cylinder bracket, and use the rockshaft from the 1711 of course.
Not sure on clearances for the fatter cylinder, but I think it would fit. This is the 1250 hydro lift And the 1711
149 with kwik-way loader,1772,two 1782 super smokers, 982 SGT w 54" haban blade,60" haban deck, 50in deck cat 0 3 point, brinly cat 0: blade, plow(3), disc.123,hydro lift. 61"O" Brinly single row planter,brinly cultivator,#2 trailer,brinly 10 inch plow,3 42 inch blades,Model #1 Tiller with extenstions,haban sickle mo. 106w/ags and hydro lift. ![]() |
1250 is ported, just no hydro lift.
Totally different parts and not worth trying to make them fit.
Yeah, im getting a new lifting mechanism for the tractor. So im sticking to the manual lift.
