Old 01-18-2013, 08:09 PM
sandreassi's Avatar
sandreassi sandreassi is offline
Default Pushing/Towing
I know I don't post very often, and when I do it's usually with a question. But, that's only because I know I don't have nearly the amount of knowledge that many here do. So, I leave the information giving to the "experts". And, I appreciate all of the help people on the, and other forums give.
With that in mind, I have another question. After a 3 month battle with replacing the cork gasket between my hydro pump and rear end on my 782, I have finally succeeded in removing he pump and replacing the gasket. I have the rear end buttoned back up and will work tomorrow to reunite it with the frame.
1. Right now it's drained of fluid. With that being the case, once I get things back together, can I push the tractor to the shed without fear of damage to the rear or any hydro valves?
2. Also, before I start putting things all back together is there anything else I should do while the tractor is split in half?
3. Should I fill it with cheaper grade fluid at first, run it shortly to check for leaks and what not, then drain and refill with Hytran and put a new filter on? Or, just fill'er up and go?
Sorry for the looooong post and, as always, THANKS for any help that can be offered.
Old 01-18-2013, 10:00 PM
jwhite jwhite is offline
ive never had a hydro but ill put in my two cents in anyway....
did you keep it clean when you worked on it...if so filler full of your choice of fluids and leter rip for a while and check on your fluids later... thats what i would do anyways..
1963 original (resto underway)
1971 cub 108 (currently on backburner)
Old 01-19-2013, 12:18 AM
Don't mix the fluids. If you've done the fix correctly, change your filter and fill it with the Hytran.
If you have a leak, (as I had in the past) you'll just have to do it over again,(as I have in the past) Have faith in your workmanship
Old 01-19-2013, 05:38 AM
sandreassi's Avatar
Okay. Thanks. I guess I will have to trust it.
Any thoughts on whether I can push it around without damaging anything when there's no fluid in it?
Old 01-19-2013, 07:02 AM
I wouldn't.
Old 01-19-2013, 11:34 AM
bluesman bluesman is offline
Default pushing a cub
this is a question that's been bugging me too. I just pushed my 1450 (full of fluid with hydro released) into the shed, about 20 ft., and some of the things I've read here have me wondering if I could have messed up the hydro unit. But then again reason suggests that there must be a way to move the tractor safely when and if it won't move on it's own. ?????????
Old 01-19-2013, 12:09 PM
cmatthew's Avatar
cmatthew cmatthew is offline
hydro release valves. if they are working and released then pushing the tractor where you need it is not a problem. towing it down the road to the neighbors house wouldnt be a good idea though.
CC 123
402c Sickle Bar, 48" Mower Deck
QA42A Snow Thrower, 42'' Push Blade
IH Back Blade and Rake
Brinly Seeder/Aerator
Brinly Lawn Rake
Brinly 10" Moldboard,Brinly Cultivator, Brinly Disc
Old 01-19-2013, 01:50 PM
I wouldn't think pushing it at a walking speed isn't going to hurt anything. Towing on the other hand is pretty hard to keep at a walking speed.
If there was no moving it at all there wouldn't be valve dumps on them. Somewhere, sometime they just have to be moved by hand.
Old 01-19-2013, 05:33 PM
He said he has no fluid in it. So it will be turning the hyd motor with no oil. Not good for the hydro. If it was full and had been run to fill the hydro it would be OK to push it.
Old 01-19-2013, 05:48 PM
Oh sure, I didn't read that part.
