Old 01-05-2013, 12:47 PM
CC102PULLER CC102PULLER is offline
Question 682 transformed into 782??
Hey guys I have a lead on a 682 thats in pretty nice condition. Asking price is $300 with deck, but Ive always wanted a 782. I also know of a frame, all hydraulics (dual), pedistal, rearend, and dash from a yellow/white cub that is the same style as the red 82 series. It could be a Y/W 782, but not sure. My question is how difficult would it be to take the manual lift off the 682 and add the hyd lift off the Y/W tractor to it, making it a 782? Or will it still need some things? I know I'll need to swap the dash for the dual levers to come out of forsure. Thanks for any help.
61' Original
100- Puller(Dad's)
102-Puller
108-Puller(Son's)
122- mower
1250-hyd lift- work horse
1650-project
Old 01-05-2013, 12:55 PM
cubby102's Avatar
cubby102 cubby102 is offline
Don't hold me to it but I think u will need a ported pump for it as well
Old 01-05-2013, 01:01 PM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
it not that hard you have to change the plastic dash peace the lift you have to change couple of things i have to get part # to explain
Old 01-05-2013, 01:10 PM
The Y/W frame has the portedpump, i forgot to mention that. But thanks Cubby102!
61' Original
100- Puller(Dad's)
102-Puller
108-Puller(Son's)
122- mower
1650-project
Old 01-05-2013, 01:18 PM
you need part numbers 7030837,7030853,7030192
Old 01-05-2013, 01:34 PM
Thanks that helps alot! I'm almost certain the y/w frame has those on it!
61' Original
100- Puller(Dad's)
102-Puller
108-Puller(Son's)
122- mower
1650-project
Old 01-05-2013, 04:21 PM
cubs-n-bxrs's Avatar
Everything should be a direct swap. I converted my 682 to a 782. The hardest part will be getting the old brackets off of the rockshaft. Should take about an afternoon to do the complete conversion.
Old 01-05-2013, 07:09 PM
yesmar74's Avatar
yesmar74 yesmar74 is offline
I've done the same swap and it's no big deal. A little blue tip heat on the rockshaft brackets helps get them off the shaft. It's well worth doing to have hydralic lift.
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake
Old 01-05-2013, 07:14 PM
samckitt samckitt is offline
What's a ported pump?
I'm a car gearhead at heart & ported means that is has been modified to flow more air/oil etc. So what is a ported pump, does that mean that the pump has fittings on it to use the hydraulics outside the pump itself?
Thakns
Old 01-05-2013, 07:18 PM
Scot,
You are correct.
The hydro pump has hydraulic ports on the front of it to run lines to run the hydraulic lift.
