Old 12-31-2012, 11:56 PM
cmatthew's Avatar
cmatthew cmatthew is offline
Default Piston ring installtion?
I did a search on here and across the web. I get there are different styles of piston rings, but everyone has a different idea on how the chamfer is suppose to go. One up, one down. both up. both down. I have the same set of rings and instructions from Stens that a fella on here posted about as to which way they were to go. Instructions says top one with chamfer up and mid one with chamfer down. Even with instructions shown on this thread. some said otherwise for chamfer position. Anybody with some light on this as to why so many opinions. Even against manufacture instruct?
CC 123
402c Sickle Bar, 48" Mower Deck
QA42A Snow Thrower, 42'' Push Blade
IH Back Blade and Rake
Brinly Seeder/Aerator
Brinly Lawn Rake
Brinly 10" Moldboard,Brinly Cultivator, Brinly Disc
Old 01-01-2013, 07:42 AM
I would follow the printed instructions that came with your set of rings.
Old 01-01-2013, 08:18 AM
cubs-n-bxrs's Avatar
As Roland stated stick with the printed instructions.
Old 01-01-2013, 08:59 AM
As stated, manufactures printed instructions take preference over the usual chamfer up positioning.
Now if you are in the quest for knowledge go here:
http://www.hastingsmfg.com/ContentDa...x?Contentid=82
Old 01-01-2013, 10:12 AM
BIGMOZEKE's Avatar
BIGMOZEKE BIGMOZEKE is offline
That is some really good information there George.
Joe
1200 Puller[/U][/B]
1864
2072 with 54 Inch Haban Blade
Old 01-01-2013, 11:33 AM
cmatthew's Avatar
thank guys. the one issue i have is the mid ring is to be installed with the chamfer down which makes the outer face of the rings bevel facing upward. in theory, scraping more oil to the top then back down the wall????
CC 123
Brinly Lawn Rake
Old 01-01-2013, 12:56 PM
cmatthew's Avatar
http://www.hastingsmfg.com/ServiceTi...stallation.htm
figure two would be what i am seeing on the oter edge of the ring. inside chamfer is opposite on my ring though.
CC 123
Brinly Lawn Rake
