Old 12-28-2012, 07:45 PM
cubfixer's Avatar
cubfixer cubfixer is offline
Default Rear lights on my 124: Any suggestions?
I am adding rear lights to my 124 while it is down waiting on a shifter. I have a repro Grote light which I will put on, but I am thinking I will want a back-up white light in addition. The red Grote may be enough, but some white will be even better, or so my thinking goes. I am thinking TSC may have what I want.
I am planning on wiring the grote to the headlight switch, and am thinking of running the white light in parallel with the grote and possibly adding a switch near the white light to turn it off separately from the grote.
Any comments or suggestions are welcome! Thanks!
John
Old 12-28-2012, 08:39 PM
sawdustdad's Avatar
Just went through this on my 108. Put a pair of the Grote lights on, wired with the headlights. The toggle switch on my dash is a DPDT, so I wired it "UP" for headlights and tail lights, and "down" for a separate (LED) backup light. "center" is off. (I run dedicated grounds to all the lights) It's just an ordinary toggle switch. If your tractor is exposed to the weather a lot, you'll want a marine grade (Carling makes them) switch. Not sure what the cub cadet switch is, the one on my 149 seems to have three positions, but I haven't had time to check it out. If it does, it might serve the same purpose.
Old 12-29-2012, 12:14 AM
Sounds good, just remember to use a fuse!
Old 12-29-2012, 07:32 AM
You don't need a fuse, just don't let the majic smoke escape when things start to burn,Ha,LOL!
Old 12-29-2012, 10:12 AM
ROFL!
Old 12-29-2012, 10:14 AM
How about a tractor light back there? This one uses the same bulbs as the headlights.
http://www.ryderfleetproducts.com/ve...t-5-p-vsm-620w
Old 12-29-2012, 10:45 AM
steve59's Avatar
steve59 steve59 is offline
Methos, I got about the same light at Farm & Fleet for about 10 bucks. I have a separate toggle switch on the dash tower (with a fuse) that runs to the back of my 1450 with a two wire harness connector for my 25 gallon sprayer pump. I made a bracket for the light and just plug it into the harness. Then take it off in the spring. I also added a flasher unit off an old combine to my tail lights so they flash like hazard lights. Sorry about the picture quality. It's off my IPhone.
Chug a lug a luggin’ 5 miles an hour
On my International Harvester
Old 12-29-2012, 12:52 PM
Steve I like that setup! I've got the light but haven't mounted it to anything yet. I've only have had it for a couple of years now.
Old 12-29-2012, 07:50 PM
steve59's Avatar
Thanks Duke....Now if I could only get some snow pushin' seat time after dark to see how bright it is...
Old 12-29-2012, 08:28 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
I have a set of them, just not mounted yet. I want to make it look stock and not drill any holes or weld any brackets.
I may just use the hitch hole and quit over thinking it.
Doug
Original , 100 , 125 , 582
