Old 12-22-2012, 08:39 AM
emptypockets95's Avatar
emptypockets95 emptypockets95 is offline
Default snowblower plugging
I got to use my 450 last night but it keeps plugging the auger up....this is my first blower any words of wisdom to keep it from building up in the feed auger ?
Justin
Old 12-22-2012, 09:02 AM
steve59's Avatar
steve59 steve59 is offline
A lot of guys spray them down with graphite to help them feed better. I used my skidloader and blower yesterday and we had a wet, heavy snow so I have to go really slow or it will plug too. If it's powder, then I can fly.
Chug a lug a luggin’ 5 miles an hour
On my International Harvester
Old 12-22-2012, 09:08 AM
cubs-n-bxrs's Avatar
Wet heavy snow is just plain hard to deal with whether it's a thrower or blower. Best you can do is run it full throttle and adjust your ground speed accordingly.
Old 12-22-2012, 10:37 AM
Iowa Farmboy Iowa Farmboy is offline
Pam cooking spray works also. Also make sure to not go from a warm shop to outside and blowing right away...as that will plug also. Allow time for the blower to cool down before starting.
Josh
1989 SGT 2072 (restored)
60"Haban Deck, 54 "Haban Blade, 48" Cub Cadet Tiller, 12" Brinly Cat O plow, 48" Cat O landscape rake
Cub 128 with creeper and rear PTO with reverser(next project)
IH built 682 and 782 that will combine to make one
Old 12-22-2012, 12:55 PM
Shaner Shaner is offline
get a snow plow
Old 12-22-2012, 04:37 PM
Got a Plow but with fresh limestone in the driveway at 150 ton and $12 a ton the blower keeps less of the stone in the drive...heavy wet 3 foot drifts are also hard to move with Plow. Thanks fellas I did take your advice and it worked better.
Justin
Old 12-23-2012, 10:27 AM
Frank1541 Frank1541 is offline
I use a 450/451. I get less plugging if I go faster for slush and very wet snow. I think this works because the volume of slush keeps things moving in the chute. This will be a problem with deep wet snow. I also found that it helps to take the spring loaded safety guard out of the chute.
