Old 12-17-2012, 09:29 PM
ploughboy ploughboy is offline
Default drive clutch
I have installed a creeper gear on my 122. Cut the shaft at line and installed coupler. Also installed new main spring, throw out bearing and teaser spring and disk. engine is at machine shop for a rebuild. Installed assembly on tractor but rod will not reach attach point unless I compress the spring. This leaves the disk loose and the main spring is almost completely compressed. I can make the adjusting rod about an inch longer and it will have tension again. Any thoughts?
Old 12-18-2012, 11:21 AM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
pic of it would help but something don't sound right.
Old 12-18-2012, 05:21 PM
found a post with measurements of a shaft w/creeper. My over all length is to long. Will need to cut to proper length and drill new hole in end next to trans.
thanks
Old 12-18-2012, 06:16 PM
shaft lenght 13.5 and center of pin hole .25" from trans end of shaft
Old 12-21-2012, 07:29 PM
Got it cut and drilled, have not had time to install. Still waiting on engine from machine shop. Hope to have all back together soon.
Pulling wood wagon by foot power is getting old.
Thanks for the help
