Old 12-17-2012, 09:50 AM
SproutW SproutW is offline
Default Hydraulic Plow/Blade Cylinder Question
I've got a blade for my 1450 Cub Cadet that has the hydraulic powered angle adjustment. My hydraulic cylinder for that blade is leaking at the front seal. I see that the cylinder is welded shut. Any chance these hydraulic cylinders can be rebuilt or and I stuck trying to find a replacement? Thanks for any help.
Old 12-17-2012, 10:39 AM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
Yes, you can if you have the right tools. I'd see if a local hydraulic place would take a look at it, to see if shafts bent or scoring. It mayl be junk.
Old 12-17-2012, 06:54 PM
Thanks for the reply. The local hydraulic place said those types of sealed cylinders are not rebuildable. What special tools do you need to rebuild one of these cylinders? I just want to make sure I can get a replacement front seal. Again thanks.
Old 12-17-2012, 07:14 PM
You'd probably be off to a good start with a lathe and a welder.
Old 12-17-2012, 07:16 PM
I've got a lathe and welders. Cut the cylinder at the weld or make a new cut? Anybody know what type of front seal is used on those cylinders? Again, thanks.
