Old 12-16-2012, 02:08 PM
BigB87's Avatar
BigB87 BigB87 is offline
Default Thinkin about making a puller
Well Ive put alot of thought into it since my 1200 hasnt been bought yet (prolly wont ever be) im gonna turn it into a pull tractor, but i have no clue where to start. The motor needs rebuilding again (smokes a bit). other than tht im clueless to even begin, i do a MWSC book...but thts it...so any input from yall wuld be great...id like to try and start pulling this spring if i can get it fixed by then. i do have a few options i can go with...i have access to a Onan motor tht runs versus the 12 hp kohler. but idk where to begin tho, not trying to go extreme, just in a stock type class or watever.
Brandon
CC models: 86, 1650, 100 w/hanban sickle mower & 1872
1972 86 w/12" brinly plow & 65lb wheel weights & 42" grader blade
1978 1650 Hydrostat w/44" mower & 42" IH push blade
1965 100 w/hanban sickle mower
1989CCC 1872 w/50c mower
Old 12-16-2012, 02:29 PM
Donny Curtis's Avatar
Donny Curtis Donny Curtis is offline
Default Puller
As for the classes near you BigB87, I would just rebuild the 12hp, find you some used Carlisle or Firestone 26x12x12 pulling tires, get you some wheely bars from, mwsc and make you some weight bars and give it a try, we will all help you on things you have questions about, Your buddy Pop will help you also, it won't happen overnite, it will take some time to get it balanced right. But you will enjoy it, I promise
Donny
Old 12-16-2012, 03:14 PM
stihltech stihltech is offline
I would start out with the 12hp you can get some good performance from them and don't have to spend a ton of money on them. Need to know what the club rules are where you are but if I can see the rules I am willing to help you with advise anyway I can. Been pulling 20+ years and worked on them professionally for 27 years.
Old 12-16-2012, 03:39 PM
Default puller
stihltech, sent you a private message
Donny
Old 12-16-2012, 04:46 PM
BigB87's Avatar
thanks on the little info so far. i guess its just down to when i can start working on it.
Brandon
Old 12-17-2012, 09:16 AM
Default puller
Donnie, sent you a reply
Old 12-17-2012, 09:40 AM
Default puller
thanks. thanks
Donny
Old 12-18-2012, 11:44 AM
BigB87's Avatar
well im going to sit down today and prolly the rest of the week and look into ordering some parts and give it a shot
Brandon
Old 12-18-2012, 05:28 PM
austin8214's Avatar
Good luck to you BigB
Old 12-18-2012, 11:40 PM
Default Puller
Brandon, will help you where I can, just a few miles from you
Donny
