Guys,
So it's fall and I did a low cut on the bermuda lawn and pulverize some leaves. Until the govener spring failed.. worked like a charm. Anyway, I'm cutting corner which are a dust bowel. I check the filter and the housing is stuffed solid with grass and debris. Is this normal- just check it and wash everytime before use? The engine is caking with fine dirt. Do you just hose it off? Is there a best way to back flush the cooling fins on my 1650? Michael |
If it were mine I would get as much dirt off the machine with air pressure.
I've always used my air compressor and blow gun after it cools a bit. Do it after every mow or any Jo. I do with it and it works.great. turn the regulator to about 20 psi to blow the filter out and crank it for everything else
No more cubs. But never fear there will be more ![]() ![]() ![]() ![]() |
+2 on the air hose, I use no water, EVER on the mower/engine.
I use the air hose @ #110 to reverse blow out the paper element on all my equipment, and blow out the ureathane pre-filters ( if so equipped) then wash in gas, when dry, treat with FFT filter oil. Yea it's messy but it does the job,and i have yet to replace a paper filter. |
