Old 12-09-2012, 02:22 PM
2cubcadets 2cubcadets is offline
Default Throttle shaft worn
Have a 26 carb that throttle shaft
Is loose. I have checked the FAQ
And it address this issue and the fix
Is a layered washer ? But doesn't
Tell where to get this washer. I have
Looked in the McMaster-Carr catalog
But no luck. If anyone knows where
To find one or has a diffrent fix I
Would really appreciate it.
Old 12-09-2012, 02:58 PM
Ace Hardware
Kohler Carb Throttle repair parts
Hillman bushing part #: 58087-A
http://wedo.hillmangroup.com/viewite...hrust-bearings
Butterfly Plate screws ...3-48 x 1/4"
http://wedo.hillmangroup.com/item/al...ilter=&by=prod
Servalite Bushing Part #: ST814-2
Old 12-09-2012, 07:46 PM
Default Servalite bushing?
Hey thank you for your help
I could not find the ST814-2
Servalite bushing on that site.
Looks like the 58087A is a brass
Washer is that all is needed?
Old 12-09-2012, 08:42 PM
The servalite is what I found at Ace Hardware along with the screws.
They are pretty cheap, pick up a couple or so to have on hand. You will also need to get the butterfly screws because you have to remove it to pull the shaft out. Don't forget to file down the back side of the OEM screws or you will break them off in the shaft and is a booger to get them out without messing up the threads. Use some blue locktite when putting in the new screws.
Old 12-09-2012, 09:31 PM
Default Servalite
Ok I am assuming that the servalite
Is used under the throttle washer?
As a seal ? If I can get this at ace
Hardware what is it other uses?Just
So if I ask for it and they don't know
What I am talking about.
Old 12-09-2012, 10:10 PM
Default Got it
I think the servalite is the name for the
Pull out bins at ace that the hardware is
Located in sorry I was a bit confused lol
Thank you again
Old 12-09-2012, 11:16 PM
Thank you again
I was just naming two different brands for the bushing. Sorry for the confusion, but looks like you figured it out. Also if I remember correctly, you should be able to use a 7/16 socket and a small hammer to seat the bushing down into the carb body with.
